When we're running at idle with the muff's on, the motor will idle smooth for 3-4 seconds then pop and then continue idling the pop again and so on. The motor supposedly has oil injection. We think the owner before us was running pre-mix as well. Is there a way to check to see if the oil pump is working withoutwaiting for movement in the oil level in the tank? Also, would running pre-mix through the motor do anything other than foul the plugs and gum up the carb more? We did change the plugs already and no difference. I pulled off the "air diverter" in front of the carbs and it's clear. Any help would be appreciated.
25ELHP Pop's at idle
Hi....this sounds like the carb/s are running on the lean side which can cause poping... I would first try and adjust the air to fuel mixture/ratio on both your carbs..... part #15 at this URL below..
http://www.boats.net/parts/search.ht...C%7CCARBURETOR
6L2-14323-00-00 SCREW,AIR ADJ
Note: turning the screws on each carb clock-wise will lean the air to fuel mixture/ratio and anti-clock-wise will richen the air to fuel mixture/ratio.
Again it hard to diagnose this 1991 with out see and know the history on this engine..... but give this a try first..adjusting the air to fuel mixture/ratio.Where there\'s a will there\'s a way
Thanks. I wish I would have seen this yesterday. I would have tried it out. Unfortunately the motor is on it's way to the shop today. My brother-in-law wanted to get it into the shop before the spring rush hit, even though it will cost us an arm and a leg.
Â
