94 200 loss of rpm
  • 94 200 loss of rpm
    engine runs great for 5-8 minutes then drops to 4600rpm
    jdh
    It could be a ignition or fuel problem. Try using a different fuel tank. If it runs ok on that fuel tank then the problem is in fuel lines or tank in boat.
      tank and fuel fine what next?
      jdh
        IF you trust your tank-side is FINE then clean your carbs.
        what is the normal running rpm before the drop ?
        when is the last time you changed fuel pumps?
        changed plugs ?
        changed filters?
        SOUNDS like your fuel supply is being cut short, as in clogged tank vent,pickup screen, air leak.
