we have a 1994 200 sws series motor and we are having oil transfer problems. we have repaired a couple of things that were not working ( main tank sensor, main tank filter, cleaned main tank ) but i ran across something that doesn't sound right. with the ignition on and engine off, when we try to fill engine tank with aux. toggle switch on motor the alarm sounds and the tank does not fill. is this correct ? i seem to remember when we used the toggle switch before the alarm did not go off. if you could help us i would sure appreciate it...........
thanks, stoney
thanks, stoney
