My engines seem to be using alot of oil. How can I check to see if this is right. The spark plugs are black and seem a little wet when I pull them out. with new plugs I get a couple hours of good running and then it starts to loose power and developes a bit of a miss, switch the plugs and its fine.
2000 200HP HPDI OIL CONSUMPTION
the motors are '00's...how long have you had them and have they always burned what appears to be excess?
Look at your oil pump while at neutral, follow the linkage to the pump, and see if the
linkage is just about bottomed out at the stop/set pin on pump body.
the brain box was replaced and it has 163 hours now, I think it may be running rich for break in still. I adjusted the linkage a little. I noticed an oil leak where the thermostat housing is on the top of the #1 side. maybe oil is getting on the injectors, the plugs are fouling on that side of the motor after a day of use.
brain box replaced and break-in? does a replaced computer still think the motor is new?
the oil setting should have been set back at the 10 hr service when motor was new.
if the oil leak you refer to is on the top
right side, it may be your 02 sensor gasket leaking.
