2000 90TRLS Hydraulic Trim
  • 2000 90TRLS Hydraulic Trim
    Can someone please tell me how to drain and/or add fluid to the Trim Unit? There is a big brass screw, should the motor be tilted up or down, and do you fill just as the lower unit? Is there a air relief valve somewhere? How about on the lower unit as well? Thanks.
    as for the lower unit fill from the bottom up. there are 2 screws on the lower unit. take both out to drain and when you fill from the bottom up fill to the top screw hole then put the screw back in BEFORE you take out what you used to fill it from the bottom hole. doing this will give you time to put the screw in before much oil drains out.
