hello
i had a oil transfer problem on my yamaha 130, the transfer was only working with the manual switch.
i read all the posts about that on this forum and i found my probleme after hours of researches :corrosion in the blue quick connector near the remote oil tank in the bilge.
not the wires going to the pump, the ones going to the oil level float....
pretty hard to find, the wire was corroded inside the sealed part of the connector, where the wire is crimped to the terminal...
i went over this connector several times before finding the problem, it was a sporadic.
thank's to jb123, ken and the others for your help
frenchy
frenchy
