yamaha 9.9 questions
  • yamaha 9.9 questions
    Just got a new F9.9ELRD. Which remote control box do i need for this motor? Is it possible to add a recoil pull start to this motor? What is the cheapest solution to add a hour meter?
    If you want a side mount control box use 703-48207-17-10. No a recoil can't be installed but you can remove the plastic cover on flywheel and start it with a rope(the starting rope should have came with motor). You can use any hour meter you want by connecting to harness on control box. The Yamaha 6Y5-83504-11-00 hour meter will record the time engine is running only.
