Am looking at a new ranger 178sv with a 150 v max carb. I understand there are pros and cons to both the carbs and the hpdis. Just looking for some input. Thanks!
New v max 150 carb or v max 150 hpdi?
take this from a ex yamaha tech of 13 years. the only bad points of a carb engine over an hpdi is a few yeah just a few dollars in gas each trip and having to choke it to start. it is much more reliable and lots cheaper to fix. as long as you check your filters and run it at least once a month, you will have no problems. i have a carbed 130 myself going on 6 years old and other then emptying the filters and routine maintenance, i have had no problems out of my 130. i would rather clean carbs then replace one injector anyday.Michael Babuchna
