2005 hpdi
  • 2005 hpdi
    i have a 200 hpdi that blew this am there were metal shavings in the #6 cylinder have you heard on any other problems with this model have been running ring free in the motor with on trouble out of engine till this
    2005 motor should still be under warranty. have you taken it to your dealer? We havn't had trouble with the 200 it's been doing good.
      the dealer said i had water in the gas that caused the motor to blow they said the number six cylinder was full of water
        dump your water seperator out in a jar to see if its so, should be full if that was the case.also the motor filter should be full of water also.
