This is my first experience changing a water pump on my 1998 Yamaha 250hp ox66 efi motor and I'm not clear about what gets changed. I've read the manual and there seems to be a lot more parts than the water pump kit shows. Does the Yamaha 61A-W0078-A3-00 kit have all the parts I'll need? How difficult is this procedure for someone inexperienced but decent with a wrench?
Help changing a water pump
The water pump has everything except for water pump housing and plastic bushing(61A-45538-00-00) on top of impeller(easily broken when tring to remove).
The motor is 1998 not 1988 and the actual number is L250TXRW. This link should bring you to the parts page. http://www.boats.net/yamaha/partsyst...model=L250TXRW
i can tell you how to get the metal and plastic bushings off without tearing them up. firstpull the housing off the water pump. if the metal cup stays on the housing, thats ok. if it doesnt, put it back on. get a crescent wrench and adjust it to fit around the drive shaft on top of the bushings and tap them down a few times. now get 2 large regular screwdrivers. while pushing down on the white plastic bushing with one, pry up against the metal cup till it starts to move. turn driveshaft and repeat. it may take 5 or 6 turns or more but it will come up but only if you hold down on the plastic bushing at the same time.Michael Babuchna
