fuel tachometer 250 yamaha
  • fuel tachometer 250 yamaha
    i have problem with fuel tachoimeter 250 yamaha, never give me right posoition, what should i check to solve that matter.
    If it's the fuel gauge not reading fuel level in fuel tank then it's probably a bad fuel sender in fuel tank. Remove the pink wire from fuel sender on top of fuel tank, turn ignition key on and touch pink wire to ground wire on sender, if gauge goes to full position then gauge and wiring is ok.
