Idles great and also runs good at top end but having trouble with engine loading up after letting idle for 4-5 minutes. Cannot get on step after loading unless I raise the fast idle for 30sec or so then it will get on step. If I don't let idle for 4-5min engine runs great but seems to burn excessive fuel. Had carbs professionally cleaned and adjusted, choke replaced, fuel pump diaphragms replaced, compression checked, plugs changed, fuel line replaced and even tried different gas tank. When engine loads up I noticed all 3 plugs are very wet. Any suggestions would definitely help.
2002 60hp bogging down after extended idle
Sounds like it is running too rich. Need to take it back to where you had carbs done and have them recheck carb synchronization and adjustment.
That may be it should have # 65 low speed jets and # 140 main jet on top 2 carbs and 145 main on bottom carb. These numbers are stamped on the jets inside carbs.
ÂÂÂ
