can any one help with this, what is the timing
94 200hp timing procedure
John its described in the periodic inspection section of the service manual. Check your email.
-Mike
mike what happened to the timing lite I have used it on my evinrude and it works like a charm.after i try this procedure I'll put the lite on and see what happensjdh
The timing light should still work and provide a good way to double check your work. At least for the idle timing.
-Mike
ÂÂÂÂÂÂÂÂÂÂÂÂ
