Yamaha Tach wiring ????
  • Yamaha Tach wiring ????
    Basically I replaced my 2000 c115 2 stroke with a new F115. My old Yamaha digital tach worked except the trim gauge and also I wanted an hour meter so I bought the new one with the hour meter. I hooked it up and the trim gauge still wont work and the oil indicator blinks I have the adapter cable 6Y5-85335-00 hooked up but I noticed the cables at the motor are not hooked up and I can't figure out where they would connect. Please help
    Thanks Aron
    And yes I did flip the dip switches
    New Tach
    These come into the motor from the harness. Where do these go? :scratch:
    If the oil lights are blinking that means the dip switch is set for 2 stroke, the trim sensor switch needs to set for 2 lead sensor. The switch's should be up,down,up. If you will send me a email address by private message I will send more information on the gauge.
