well its very possible because you made them premix and sometimes you are getting 4 times the oil needed. not to mention your o2 sensor will probably foul out pretty fast if not already also.
i tested the 02 sensor replaced it now there is now more problems for now the boat the motors are on is a comercial fishing boat full of water and fish scales not well looked after that is the reason for takeing off the oil injection will i now need to clean the 02 sensor more often
