Hello,
I am having a problem with my Yamaha 200OSX engine. The symptoms are as follow:
Ignition alarm goes off during and after start with the engine cold.
Engine runs well at low RPMs.
RPMs increase and decrease while running throttle in a higher setting.
Water flow through the engine looks fine.
Oil level is high.
Boat was okay until a few days ago when the spare battery was removed. Similar symptoms manifested less than a year ago. Ignition switch had to be replaced as a result. I would like your opinion before I incur the expense once more. Please advise if there is any basic troubleshooting I should do. Also, please suggest a good technical manual for troubleshooting.
Thank you in advance,
Oil level is high.
