I'm instlling a 94 225 HP Yamaha TXRS and need a wiring harness and gauges. I need part numbers and suggestions? Can I use my exisitng binacle controls from my 86 Evinrude 225? Thanks Dad on a budget!
225 HP repowering
The main harness and switch panel is:
704-82570-08-00 Single Main switch Panel
6X3-8258A-00-00 16ft Harness
6X3-8258A-10-00 20ft Harness
6K1-8258A-40-00 26ft Harness
61B-8258A-01-00 31ft Harness
The Multifunction gauge kit for 2004 and earlier motors are not available any more so you have to get the gauges and harness seperate.
If you want 6Y5-8350T-81-00 Digital Tach or one of the Pro Series tach with warning lights then order 68F-82553-70-00 trim/oil harness and 6Y5-83553-M0-00 gauge harness. You can see gauges athttp://www.boats.net/partsystem/common-parts.pl?group=5&cart_id=176aae9bf4f048050624256c2 b0d65ca
