I HAVE A 1987 YAMAHA 30 SH. I WANT TO ELIMINATE THE OIL INJECTION, IS THERE A BLOCK OFF PLATE FOR THE PUMP HOLE. IS THERE ANY REASON THAT A SHAFT MUST BE IN THIS HOLE.ANY INFO ANYONE HAS WOULD BE GREATLY WELCOMED THANKS.
oil injection block off plate
I recently removed the oil injection system on my 1987 90ETLH and have a couple questions. I currently have the oil pump installed with the drive shaft removed and all ports plugged, is there a blanking plate kit available? Also do I need to splice the oil tank level switch wiring through so the engine will run properly so the engine control system thinks the oil tank is full?
Thank!
Originally posted by BQUICK View PostGear should be removed. I would get a block off plate from the commercial 85hp non-oil injected. As far as the oil level switch I put a zip tie on it to fool it into thinking level is full. Then just lay it under the cover....works for me.
