air cooled 3.5A won't run when hot
  • air cooled 3.5A won't run when hot
    Hi, My 3.5A air cooled engine won't run over 1/4 throttle when hot. it will run for about 10 minutes (a mile) on full throttle from cold, and then just dies unless you throttle right back.
    it's a pain in the butt. I've had the carb apart, and checked the float and needle etc, no grooves. could the fule be evaporating before entering the cylinder, could it be a weak spark?
    Any bright ideas welcome.
    Have you checked the vent on gas tank?
      yes, even had cap completely off gas tank :-(
