My tilt trim will leak off completly. It will go all the way down and tuck under when it sit for a day. 150 ProV 1990. What is the cure? Thanks for any info.
Tilt Trim leaking off
it is one of two things. the manual release valve is not seated right. raise all the way up, loosen the screw to let it drift down and retighten right before its all the way down. the other cause would be the relief valve in the front or the trim unit. for this you have to remove the motor from the boat. better left for a mechanic.Michael Babuchna
