Tilt and Trim Switch in Shifter-Yamaha 200
  • Tilt and Trim Switch in Shifter-Yamaha 200
    I have a 1995 200 hp Yamaha outboard. Does any one know how to remove the trim switch from the shifter arm. I have a manuel but it shows to remove a screw, there is not screw visible. It works when it wants to. The switch in the front works the tilt and trim fine, so it must be the switch in the shifter.
    Thanks,
    Don
    Don
    If you have the 703 side mount control box then remove the handle from control box and remove the red neutral lock then you can get to the screw that holds the grip on.
    704 binnacle box, remove the screw at base of grip, remove grip and then you can get the screw that holds the switch.
      Thanks. I was afraid I would have to remove the handle. I will give it a shot. Again thanks for the help.
      Don
      Don
