Hi guys. 89 225 excel the while under way say at 4400 will drop to 4200 then after a while goes back up. It also will do it at 4000 to 3900 but much less often.
I am thinking TPS? Any ideas? Thanks
you want to move the throttle very slow and look for needle jumps of any kind. set the meter to 2vdc to start, then once you get to about 3/4 throttle position, you will need to set it to 10vdc. i wish they meter with a 5vdc scale, i have looked.
