Replacement for rigging hose
  • Replacement for rigging hose
    I believe the flexable hose that the remote control cables pass through is called rigging hose so that is what I am going to call it.
    My rigging hose is falling apart and I am looking for something to replace it with. I have considered spiral wrap but the largest I have been able to find is 1".
    I prefer not to take all the cables loose from the engine.
    Anybody got any suggestions?
    the harnesses, cables need to be unhooked at one end or the other to be put thru the rigging tube so you may want to wrap them.
      Thanks but that's not what I asked.
        Anyone?
          Try TH Marine. They have all sorts of rigging tube products. They are online, you may need to Google them.
          D-
            You can just get that same rigging hose and cut it open lengthwise to wrap around your rigging cables and then use black tie-wraps around it every foot or so to hold it back together. I've seen zippered rigging tubing too but can't find the link right now.
            -Mike
              Thanks, I have ordered a Zippered Rigging Sleeve from iboats.com.
