i have continuation of a problem which i thought
for a fuel problem (you can check my last posts ).
but now it seems that i miss the source of the problem and it looks like one of those frustrate electrical problem .
cutting-off the plugs will show:
cylinder #1 very very weak and stay wet .
cylinder #2 responding little strong then #1 .
cylinder #3 will almost shut the engine (very strong ) .
on my last post "jb123" suggest that i swap my coils i did so and a number of other checks .
clean carb
Compression check , 120 all 3
Swaped plugs, coils
the no #1 plug will always stay wet and the other plugs like i described .
i know thet it looks like pulser coil or cps sensor or charg coil or cdi unit but
what is the right order or way to check them .
clean carb
Swaped plugs, coils
