hi guys got my boat rigged and every thing works but i notice that the senders on the furel management are leaking a little bit after i prime the bulbs i used brass male fittings to barb connectors with the proper thread patter and i wrapped them in teflon and tighted down but they are leaking and one have any ideas is this common from the begging or does it have something to do with the bulbs being pumped thanks for your help
fuel management senders
if you do hook it up like hamfisted said, just keep in mind whenever you go to install a new filter or you take it off to dump it, your gonna have to fill it back up with gas or gas and oil(depending on your motor) or you will never get it to prime up with the bulb. thats why i put it before the filter. if your tank has that much trash in it to clog up your primer bulb, you better be cleaning it out.Michael Babuchna
