grinding noise when shifting
  • grinding noise when shifting
    200hp, 1988 yamaha runs great, 1400 rpm when in neutral, grinding noise when shifted to forward or reverse.
    Idle adjust?, shift cable adjust? if so please explain how.
    Please help. TIA
    tony
    yes your idle is way to high. it should be 800 in neutral. it might be to late and you may need a new clutch dog in the lower unit.how are you shifting it from neutral into gear? fast or slow. you should be "popping it into gear as fast as possible but not giving it any throttle. it takes some getting used to but this is the correct way to shift. start off by lowering the idle.
    Michael Babuchna
      Thanks Slim,
      Do i adjust idle screw or should i adjust throttle cable ?
      tony
        the idle screw on the starboard side of #2 carb. its pointing straight down. you need to back it out. im affraid that it might be to late for your clutch dog and gears though. you might have to replace them anyway. do you shift fast or slow?
        Michael Babuchna
          Thanks again Slim,
          I just purchased boat and motor only had it out once,i did not know on shifting quickly but will in the future.
          I know the previous owner mechanic who worked on this motor and will be contacting him .
          tony
