I posted under this same topic 2 months ago (July 17) and thought we had it licked, but intermittent problem persists. Back then, it was thought to be a fuel flow problem of some kind. I took the carbs off and removed the bowls. Spotless. Replaced the water-separating fuel filter. Blew out the fuel line from filter back to the tank and from filter to motor. Blew out the tank vent tube. Changed the plugs. Changed out the primer bulb.
Boat still ran at 80%. Fair power, enough to pull skiers, but those of you with a similar motor know what it can really do. Top end at 5200 rpm vs 6000.
Then, next time out, it ran great. Full power and top end. Next several trips, it continued to run great. Then, ran rough for the first 2 minutes, then great. Next time, rough for about 30 seconds, then great. (Had added a can of SeaFoam for that one.) Last time, back to 80% the whole time. Checked plugs and they look OK.
Any more (or same) suggestions?
Thanks again. Steve
Thanks again. Steve
