To replace the gauges is it as simple as buying them on e-bay and plugging them in? The current ones work but the LED's are shot. What should I look for? Thanks.
replaces gauges for a '98 250 hp
no uppy, it is not as simple as that. yamaha has started using the same guages for all there motors, 2 and 4 stroke. new guages have tiny dip switches in the back to switch from 2 or 4 stroke, different pole settings for different motors and one other to change display units(mph/kph). they should come with a tag in the box to show you how to set them. hope this helps.Michael Babuchna
Slim,
It does help. The gauges that are offered here specify earlier motor years, which cover my motor. One more question, can you keep the existing harness and just flip out the gauge or do you have to replace the entire harness?
if you use a new guage, you need to get a new harness. on a new one you get both the oil and trim harness in one. on the older guages, they are seperate. the plugs are different but i cant remember exactly when they changed the plugs.Michael Babuchna
ÂÂÂÂÂÂÂÂÂÂÂÂÂÂÂ
