'94 70hp precision blend.
when I put the motor in gear, forward or reverse, I get an unfriendly grinding/clanking type noise for a second or two before the prop fully engages, then it goes away and things seem ok. Any ideas on what this could be? lower unit gear slipping? Prop not installed correctly? When I took the prop off and changed gears, the affect wasnt nearly as pronounced, but still think I heard a similiar affect.
any input appreciated.
thanks!
jim
thanks!
jim
