1993 70hp Trim & Tilt Problem
  • 1993 70hp Trim & Tilt Problem
    Motor tilts down, but not up. Any ideas? Is this something I can fix myself. Can hear the clicking, as though it should be working, but motor doesn't raise up. No fluid leaks.
    Could trim switch, wiring or trim relay. If you hearing relay clicking then the switch is probably ok. Probably a bad relay
