adjusting new trim gauge
  • adjusting new trim gauge
    I have a 2004 yamaha 50TLRD i installed a trim gauge made by teleflex morse. In the install instructions it says to adjust sensor if gauge doesn't read correctly. I can't seem to find the sensor or a way to adjust it. I have followed the pink wire but can't tell where is goes. When using trim guage will rest at 1/4 up from full down, and when you engage trim to go up motor will move only a couple inches and gauge will read full trim. Any help is appreciated
    The trim sender is underneath transom bracket, tilt motor up all the way and follow that pink wire to sender. To adjust loosen the 2 screws and rotate sender back and forth.
