Water Pressure Gauges
  • Water Pressure Gauges
    I want to Install Water Pressure gauge on twin 1999 250hp S250TXRX. Purchased water pressure gauge 6Y7-83660-10-00 from B.N. I thought sender would come with. Does anyone have part number for sender? Is it 688-83667-00-00 and do I have to run wire to the gauge(s) ? Do I need anything else ?
    688-83667-00-00 Is the correct part number for the water pressure tubing.
      tbrown,
      You also need a fitting that screws into the top of the cylinder bank that the tubing attaches to.
      If you had bought a "gauge kit", it would have come with the gauge, tubing, and fitting.
      Boats.net will know the correct fitting for you.
      I used a 90 degree "elbow" fitting on mine.
      Be sure and use a thread sealer (I use Permatex 14A with Teflon).
      There are no wires to run - just the backlite wiring on the gauge itself.
      Ken K
