Yamaha outboard help...
  • Yamaha outboard help...
    Hello,
    Recently purchased a Yamaha 2002 115 hp 4 stroke. It is some model that was made for Eurpoe, but is the same as the US F115 model.
    I have the outboard connected to Yamaha 703 controls. Outboard runs great and shifts well. I would like to now add gauges to the outboard. I am unsure if Yamaha makes a wiring harness for the gauges and if so then which gauges are best for the outboard.
    Any help/guidance is appreciated.
    Hi Leon,
    I am sure Yamaha makes a harness for Gauges for this outboard. Probebly the same for many models. For starters I would go for a Tachometer, water pressure, oil pressure, maybe temp as well. Many other qauges are available as well. Good luck
    Jon
      I broke down and bought a Yamaha Digital multi function Tach and rigging kit. Now my new problem...tach works fine. Trim is not correct. I am not sure about the oil pressure or temp warning lights.
      The harness has four wires that go to the controls. All are connected. The blue wire is only a wire that is not connected into the gauge.
      I also have a four pin connector that goes from the engine to the gauge. One the harness there are two wires. One is red and one is black. All I can find on the engine side is a similar connector with a pink and a pink/black wire. Only one wire would make the connection (since the black is connected to a dead terminal).
      I am pretty disappointed since I made sure to buy a genuine Yamaha multifunction gauge, control, and harness.
      Thanks for any help.
