dont know how to ues thoes things and where can I get thoes?? please help !! newbie again ~_~
shock treatment with SeaFoam or RingFree!!
Runner,
Locally, I get SeaFoam at Advance Auto Parts - other auto parts stores carries it also.
RingFree is Yamaha branded - any Yamaha dealer will carry.
The shock treatment I use is as follows - from a previous post - this will de-carbonize your motor and cleanup the fuel system somewhat. If you use RingFree, the procedure is on the bottle. But if your carbs are clogged bad enough, you will need to tear down, clean, and install a carb kit:
Two strokes build up a lot of carbon internally and need to be de-carbonized by doing a "shock treatment" with a detergent like Seafoam.
I like to do the shock treatment once a year on my C115 - in late winter when I am going thru my list of "spring make-ready".
If you use a detergent like Yamaha Ring Free or SeaFoam all the time in your fuel tank, then the carbon buildup is not as bad. Still, a lot of 2-stroke owners will de-carbonize once a year - you will get various opinions on this.
I "shock-treat" my C115 by running the following mixture thru it. This will smoke up the area pretty good, and leave a lot of carbon on the drive way:
16 oz can Seafoam
3/4 gal gas
3 oz oil (2 if oil injected)
Disconnect the fuel line at the input to the bulb and attach a three foot piece of fuel line to the bulb. Mix the above in a small container -
I use an empty 5 quart oil jug. Set the container on the deck of your boat and insert the fuel line and secure to make sure the end stays on the bottom of the container. Pump up bulb and start outboard with earmuffs and water hose, of course -run a little above idle for 15 minutes and turn off. Let sit for 15 minutes. Run again for 15 minutes. Let sit 15 minutes. Repeat until all mixture is consumed. Reattach main tank hose to bulb and run regular fuel/mixture thru motor for 10 minutes - you want to get the concentrated detergent out of the fuel system.
Now, clean up the drive way before your wife sees all that nasty carbon and makes you get rid of your boat.
Ken K [img]smile.gif[/img]
