Went to use the boat and found the motor would not lift and ignition would not turn motor... Looked around a bit and found the 20amp fuse blown. I changed the fuse and the wires around fuse got warm... Ignition and tilt worked... fuse blew again.
I have ordered the manual but would like to go fishing. Anyone seen a cause for the 20 amp fuse to blow. 30 amp fuse is fine
