Oil Pump Linkage-115TLRQ
  • Oil Pump Linkage-115TLRQ
    My oil pump linkage (the plastic part) cracked.
    Ordered new part and need to know how to adjust
    the linkage. Checked other posts but did not understand. I appreciate your help.
    install the ends on the arm, click both into place. in neutral, look at the oil pump itself, then the spring loaded part of pump. there is a stop pin on pump and the "dial" i would call it needs to stop/rest on the pin at neutral.
    if you have the arm off, the spring loaded dial will sit on the pin, look you will see it.
