225 4 stroke -- gas mixing with oil
  • 225 4 stroke -- gas mixing with oil
    originally thought is was the temp sensors running the engines cold, causing the engines to shoot more gas into the engines, resulting in the gas getting into the crank house and then over flowing into the oil reservoirs. put in new temp sensors, but it did not solve my problem. oil/gas will flow out of the dipstick hole when checking the oil...any thoughts as to what the problem is? occurs on both of my engines.
    HI, i read your post a couple of times, on different dates, and I am unable to help, but I have the same 225 four strokes, and was wondering if you solved the problem, and if you did , what did you do? I would love to know, because sooner or later it will probably happen to me, or someone else on this forum.
    thanks, Dennis
