1994 Yamaha Pro V 200 Horse Power
Engine missing at higher RPMs (not low oil saftey/rev. limiter)
Volt Meter at 10 volts tested Original rectifyer according to shop manual and it failed test. Replaced with new rectifyer ran boat, problem not solved, new rectifyer failed continuity test after running boat and testing per shop manual.
Question 1: What would fry rectifyer.
Question 2: What is the correct method to test a rectifyer.
