Our trailer broke on the way home today and the lower guard on our 1988 Yamaha 40 HP Precision Blend Engine snapped off. We would like to know where we can purchase just the lower case with the prop guard attached. We don't need the gears, etc. Just the alumimun case. Anyone know where we might get this? Possibly in Northern California?
1988 Yamaha 40 HP Precision Blend Lower Unit/Gear Case?
You don't need to replace the entire lower case - just have a welding shop weld on a new skeg - this is a fairly common repair on lower units - check with dealerships to see which shops the service dept can recommend - also, can look for prop repair shops, most of them do skeg repair also.
Ken K
Thanks for the suggestions . Its worse than you think A 2" wide hole into the back of the torpedo ripped out when back half of skeg disappeared. I will take it to the local shop but with a machined fit for the rear cap screwed up by the missing piece & 2 vertical cracks one up each side I am sure its toast! Just missed aprat at the local dealer who sold it last week
ÂÂ
