Just bought an aftermarket thermostat on Amazon. The stat fits nicely but the top of the stat is larger than the OEM, therefore the metal gasket wont fit over the top of the stat. Problem?
Yep, my C90 thermostat has a rubber seal ring around it's circumference....
I believe that with a bit of checking and cleaning on a yearly basis the Yamaha thermostats will last for many years....
