On my 6hp kicker (1997) the control box will go back in reverse but the cable won't push far enough to put the motor in reverse. If I go back to motor and pull on the cable it moves 1/4 to 3/8 of an inch more and goes into reverse. I sprayed lubricant in the cable and worked it back and forth didn't help. I can't adjust the yoke on the end of the cable anymore or it will fall apart. I don't see any adjustment on the control box either. Is it time for new cables?
Thanks Reddog
Thanks Reddog
