Help with pump/electric motor
Our sausage turned out great as always.
60lbs of deer/pork about 1 lb links
cold smoked in our smoke house while it snowed I think. Hard to keep track of the days things happen when old and retired.
also 10 lbs of summer sausage.
have 6 lbs of Canadian Bacon( pork loin) curing now in the fridge, will hot smoke next Sunday or later in week
that biscuit looks like it would be hard to eat and very messy to eat but may taste very good
Originally posted by 99yam40 View Postwhat is the RPM of the 2hp motor?
do you need to spin the generator at any special speed?
might try changing pulleys again to get more torque , but may turn the unit too slow to get enough output
Output is about 70 AC volts unloaded. About 80 DC volts unloaded. Enough to kill me I suspect if I don't keep my fingers away from the electrics.
Originally posted by boscoe99 View Post3450 on the data plate. 1200 RPM on the rotor.
what is your target RPM and Voltage you are shooting for?
or is it amps you are targeting?
Maybe a 3 to 1 would be betterLast edited by 99yam40; 12-12-2017, 09:25 PM.
ÂÂÂÂ
