Yamaha 115 alarm
  • Yamaha 115 alarm
    Received under dash alarm by key for water in fuel. Took out fuel filter cup cleaned and replaced filter....alarm still on. Disconnected fuel filter sensor alarm still on. Had engine coded she shows no codes. Alarm goes off when boat is geared. Bad alarm??? At a loss here. Is there a sensor or alarm in the initial separator?
    What is the primary id and the model number?
    Y is so f****** hard to post it?
      Motor model is a F115xb on a alumacraft trophy 176 6ekx 1007186
        You still have water in fule
          The sensor is is the fuel filter cup. If you disconnected the sensor yet the water in fuel alarm remains I would suspect a wiring problem. If not a wiring problem an ECU problem. Given that the system is working insofar as the alarm sounds with the motor in neutral but stops when the motor is in gear would lead me to suspect a wiring problem.
          Do you have a multimeter?
            Take a fuel sample in a glass jar, water will be on the bottom.
              I do have a multi meter
                Never saw any water in the fuel
                  the alarm syetem foe water detect on that model will ONLY sound if it is in N.
                  any gear position and the audible WILL NOT sound.
                  dumb as ell but I did not program the ECU.
                  if you get a water detect with the fuel cup dissconneted I would look for a shorted wire.
                    Absolutely wonderful, looking for a needle in haystack
                      not quite so bad as that.
                      There are two wires in the WIF lead, black IS ground
                      and the other (blue/white) should run to a pin on the ECU
                      unless the problem is within the potted ECU (unlikely)
                      it can only be somewhere along the length of that blue/white wire
