I have an 1997 C80TLRV 80 horsepower Yamaha outboard. The motor has been running great and I recently, 2 months ago, replaced the water pump as routine maintenance. I have taken the boat out a couple dozen times since I changed the water pump with no issues. I generally only run the motor about 1/2 to 3/4 throttle, however, today I ran full throttle. After about 3 or 4 minutes at full throttle, the warning buzzer sounded. I pulled back to neutral and the buzzer stopped after about 30 or 45 seconds. There was a very strong stream of water coming from the engine. I pulled the engine cover and the engine was cool.
Any ideas as to why the buzzer sounded?
