I am thinking that something like that could leak very easy and cause the motor to catch on fire
F225 TXRC bogging down - fuel rail pressure question
Originally posted by rodbolt17 View Postmyself I would test the rail pressure at the RPM and LOAD when it fails.
otherwise the test is a teat on a boar hog.
that vacuum sense line on the regulator allows for about 5PSI more rail pressure at or near WOT or when rapidly accelerating.
Originally posted by boscoe99 View PostWhy is that?Originally posted by Crazy Train View PostAs an aside, it would be nice if the VST could be modified with maybe a 1 inch diameter side access 'hatch', like a screw on gas cap, level with the HP pump filter so that the filter and VST interior could be inspected without ripping the VST off the engine.
Originally posted by Crazy Train View PostI it would be nice if the VST could be modified with maybe a 1 inch diameter side access 'hatch', like a screw on gas cap, level with the HP pump filter so that the filter and VST interior could be inspected without ripping the VST off the engine.
The HP pump filter does not really need to be within the VST.
Gasoline initially entering the VST has been filtered by the primary fuel filter. That gasoline having normally already having been filtered by a boat mounted water separating fuel filter.
The HP pump filter I suppose it to try and capture any contaminates that have gotten into the fuel system either from the pump itself or down stream from the pump. An external filter could be mounted adjacent to the VST to filter any bypassed gasoline that needs to re-enter the VST.
Were I the engineer that is the way I would do it. But if I owned the company there would no VST installed at all.
Originally posted by fairdeal View PostAnybody else remember the Holley "Visi-flow" used on Fords and IHCs?
For the OP, did you drain the VST and see if any crap came out?
Should be one screw on the bottom and a hose connected. Obviously catch what comes out in a small clean container.
I'll drain mine occasionally AND prime the bulb to push fuel thru it for inspection/flush..
.Last edited by TownsendsFJR1300; 11-27-2017, 05:35 PM.Scott
Originally posted by TownsendsFJR1300 View PostI don't remember the above carb but Holly and others DO have a see thru "plug" (approx 1" across) for adjusting the float level correctly(with the carb installed), see below.
For VST access, I was also thinking of 1 inch diameter tube, threaded on the outside, that is capped off with a female cap similar to a wide-mouth oil container, but that visi flow window would be perfect - clear to see in AND access to suction off the HP pump screen and VST bottom.
Thanks!
Originally posted by 99yam40 View Postthose float chambers are not under pressure like the VST is.
2004 F225TXRC Yamaha Outboard FUEL INJECTION PUMP 1 Diagram and Parts
Maybe a misunderstanding, or I missed something..Last edited by TownsendsFJR1300; 11-27-2017, 08:14 PM.Scott
I've never changed /checked the VST filter on my engine (original owner) but I keep after exterior filters, drain the VST on occasion and use fuel additives (Non-ethanol fuel too).
BTW, it has been mentioned in previous posts you can spray carb cleaner up the drain in the VST. Wether the spray would actually hit the filter, dunno for your engine. Probably couldn't hurt(and easy too).
.Scott
Originally posted by TownsendsFJR1300 View PostThe VST isn't under pressure(not much to speak of till the float shuts off the needle valve)... It's got a needle and float and a vent:
\ Maybe a misunderstanding, or I missed something..
Originally posted by 99yam40 View PostI am under the impression that the VST is not open to outside air until a relief valve opens. fuel in VST does not evaperate away like a carb bowl
At any rate, not that big a headache to remove VST to clean. Now those little screws and funky gasket can be aggravating.Last edited by pstephens46; 11-27-2017, 09:50 PM.
