Corrosion
The picture shows corrosion around the holes where other metal such as a bolt had been. This greater corrosion is because the metal composition between the plate and the bolt (or the fastened component) is different, setting up an electric field just like in a battery. If you place that bracket back but do not bolt some of the holes the corrosion will slow down at these places. Overtime the corrosion pattern will change.
It is interesting the part the water plays. For rust to occur at "room temperature" water is needed as an electrolyte, ions being able to move better within salt water than fresh. It is the conductivity of the water and not the amount of oxygen dissolved in the water. Salt water holds far less oxygen than fresh but iron rusts (the chemical combination with oxygen) quicker in it.
Perhaps the coating was applied a bit light on that part. Do you have similar corrosion elsewhere (similar metal) on other parts?
I'd sand those spots to bare metal. Rustoleum has a "galvanize spray" (rattle can) that works really, really well... Couple coats and it'll last a long time...
(I used it on my steel lift extensions). I had to weld a tab to a new extension (ground down to bare metal) and I used that. It gets soaked in brackish/salt water whenever the boat is lowered... Been that way 10 years, NO RUST...
Plus one with 99 as well, once assembled, soak that power head with LPS or similar...Scott
Maybe there is more dissimilar metal attached at these ends that forces the steel to "sacrifice " more. Being at the ends means there is less sacrificial metal there.
More likely those areas retain the moisture more, maybe don't retain enough engine heat to dry off.
You will probably scrap off and neutralise the rust and paint with a zinc rich paint. If you can get zinc washers you could also if worth the trouble add more galvanic protection there.
Originally posted by TownsendsFJR1300 View PostPerhaps the coating was applied a bit light on that part. Do you have similar corrosion elsewhere (similar metal) on other parts?
Plus one with 99 as well, once assembled, soak that power head with LPS or similar...Attached Files
Yep, ^^^, those products work good...
And Pat, you can do a cover/final coat of silver or black and it'd look stock..
* I had powder coated a bracket I made (years back) to hold my "dock box" to a davit (now sold). The powder coat started rusting so I sanded all of that off and finished with the above product.
Final coat of Rustoleum shiny grey, lasted years (no rust) till I just sold them..
.Scott
ÂÂÂÂ
