Cheap Seastar fluid
  • Cheap Seastar fluid
    Mil-5606 Aeroshell $32/gallon. Seastar $27/quart.
    Local distributor near airport. Probably find one in most decent sized cities.
    $5.95 a quart from here.
    https://www.aircraftspruce.com/pages...s66XC5606H.php
      $5.95 a quart from aircraft spruce
      Phillips 66 X/C 5606
      Pilot Supplies and Aircraft Parts from Aircraft Spruce.
        www.aircraftspruce I can't add the dot com because it goes into neverland.
          Shipping??? Plus I want it NOW!
          I bet Fairdeal has some of this at the abode in Warmland.
            Panasonic?
            This 5606 Hydro fluid. Can the excess I may not need be stored in a plastic bottle? Might there be issues?
              If your planning on using it in a airplane in the future then it must stay in the original container and sealed (plastic lids that fits on those cans)
              But I don't think you are going to do that....so a motor oil plastic bottle clearly marked 5606 HYDRAULIC FLUID would be good.
              Why don't you just use ATF????
              What are you putting it in?
                Seastar docs say 5606 ok to substitute for their expensive steering fluid.
                  That's what I thought. If it is only $5.00 a quart and you can get it readily then 5606 is fine. But ATF will work perfectly fine in a steering system like that.
                    when the need first arose, I refused to buy the Teleflex Liquid Diamonds - IIRC I googled a gallon of 5606 - shipped - for the price of a local Seastar quart.
                    That savings was enough to satisfy me - although I have no doubt ATF - or even Tractor Supply hydraulic oil - would work fine.
