Cheap Seastar fluid
$5.95 a quart from aircraft spruce
Phillips 66 X/C 5606
Pilot Supplies and Aircraft Parts from Aircraft Spruce.
www.aircraftspruce I can't add the dot com because it goes into neverland.
Shipping??? Plus I want it NOW!
I bet Fairdeal has some of this at the abode in Warmland.Last edited by pstephens46; 11-14-2017, 07:13 PM.
Originally posted by pstephens46 View PostThis 5606 Hydro fluid. Can the excess I may not need be stored in a plastic bottle? Might there be issues?
But I don't think you are going to do that....so a motor oil plastic bottle clearly marked 5606 HYDRAULIC FLUID would be good.
Why don't you just use ATF????
What are you putting it in?
when the need first arose, I refused to buy the Teleflex Liquid Diamonds - IIRC I googled a gallon of 5606 - shipped - for the price of a local Seastar quart.
That savings was enough to satisfy me - although I have no doubt ATF - or even Tractor Supply hydraulic oil - would work fine.
