Originally posted by rodbolt17
View Post
F300 2015 VST Draining for Winterizing
Stumpted. I see a connector to the right on the top and a plate to the left side with 3 screws.Last edited by knowhowiroll; 11-20-2017, 03:02 PM.
strange it won't allow attachments when I pick the paperclip
I can see the top of the VST however nothing similar to a black tab or plug
I can see a connector to the right and a flat plate with 3 screws to the left and couple of hoses going down into VST and to smaller hose coming from the side.
How long does it take to empty VST and fuel cup at idle.Last edited by knowhowiroll; 11-20-2017, 08:03 PM.
Wish I could do that post image thing but I am right in the middle of my engine idling getting dark and waiting for some mix to run thru that I put into the separator.
If I could empty the VST and fuel cup ibekive I would probably be thru the mix going thru. I have been idling 15 minuets on the muffs and haven’t seen any smoke. Gonna get cold tonight and I want to ry wrapping this up in a bit.
Update on draining VST
Yep good tip on refilling the VST after draining it.
I removed the grey line with a red stripe from the top of the VST, unscrewed the drain valve and about 8 - 10 oz of fuel was decanted. Re primed the fuel cup and VST and all went well on that step.
Bad news is I believe I ran the impeller without sufficient fluid on a subsequent step (trying to run RV antifreeze through the muffs) and now the engine is not pulling water Oh well now I have to pull the lower unit and fix that.
Originally posted by pstephens46 View PostHow long did you run it in this suspected condition? They can take a little abuse.
Didn't think the V6 300 needed the antifreeze anyway. Just the V8.
Michigan. To do the winterizing part I taped the water inlets at front of the foot used muffs without disconnects and had the flush connect going as well.
The issue with impeller happened after I switched to the RV tank. No flush connected of course.
Was leery about even thinking about it weeks ago as part of the procedure. It always has a very weak stream even on the muffs and flush connect imo. Just never seems as strong as low speed idling while underway.
Just not enough pressure imo. Won't be doing that anytime soon
Are we chasing a ghost? Damn if I can find a plug for a Schraeder valve on that particular model.
You can drain the VST but it is going to be very very difficult to drain the entire fuel system. Why not treat about a gallon of gasoline with a fuel stabilizer and simply run the motor until that mix has been fully ingested? The entire fuel supply from the fuel filter onward will have been treated.
Originally posted by boscoe99 View PostAre we chasing a ghost? Damn if I can find a plug for a Schraeder valve on that particular model.
Now I see where the mix was added to the separator.
