the ign coil output is in the kilo volt range.
the input is 12v.
the ringing effect is typically 150-250n volts PEAK.
you CANNOT read peak voltage with an RMS reading meter.
aint gonna happen.
sooty black plugs indicate it is running rich.
a fouled plug will load the voltage down.
why not make or buy a spark tester?
why not simply observe what the system is doing?
you gotta understand inputs to a device and the device outputs.
dunno what sensor your testing put the pulser coils are two wire devices.
the input is 12v.
aint gonna happen.
